Activity Forums Apple Final Cut Pro Legacy converting wmv to mov in OS 10.6.8
  • converting wmv to mov in OS 10.6.8
    Posted by David Mayer on September 25, 2014 at 10:04 pm
    I am running FC 7 with OS 10.6.8
    Works great
    But I need Flip4Mac or something else to convert .wmv movies for Final Cut.
    Flip4Mac requires OS 10.7
    Don’t want to upgrade and have FCP not work in 10.7.
    Suggestions for converting .wmv movies?
    (I have tried Compressor, MPEG Streamclip and ClipWrap.)
    Dave
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.8
    Final Cut Pro 7.0.3
    Canon C100
    Chris King replied 9 years, 10 months ago 5 Members · 6 Replies
  • Shane Ross
    September 25, 2014 at 11:27 pm
    FCP 7 works under 10.7 and 10.8. No issues.
    Biggest issue will be finding them to install…
    Shane
    Little Frog Post
  • David Mayer
    September 26, 2014 at 11:26 am
    you mean i need to find disks?
    OS 10.6.8
    Final Cut Pro 7.0.3
    Canon C100
  • Shane Ross
    September 26, 2014 at 1:41 pm
    10.7 was a disc. 10.8 was the first download only. But I don’t think they sell it anymore. For 10.7…you might need to see if someone you know has that, or look on eBay
    Shane
    Little Frog Post
  • Lopez Parri
    October 4, 2014 at 4:22 am
    Go and get AppGeeker converter, it works well in converting between videos including .wmv file.
    It’s quite simplistic in design but I normally just set it to iPad Air and let it do it’s thing.
  • James Emily
    April 9, 2015 at 7:09 am
    To import WMV to FCP, we had better convert WMV to FCP more supported Apple ProRes MOV. iDealshare VideoGo is just the right one which can convert WMV to MOV(Apple ProRes) or MOV(QuickTime) on Mac OS X.
    Step by step guide at https://www.idealshare.net/video-converter/wmv-to-mov-converter-mac-windows.html
    It also can convert AVI, MKV, ASF, FLV, VOB, 3GP, AVCHD, MXF, MTS and etc to Final Cut Pro supported Apple ProRes MOV
  • Chris King
    October 21, 2016 at 5:39 am
    Well, you can’t edit a WMV video in Final Cut Pro directly even you upgraded to FCP X. To solve the issue, you need to change the file extentsion from “.wmv” to a codec that FCP can read more easily (without rendering basically). The codec is Apple ProRes, which ensures maximum editing quality and efficiency when working with Final Cut Pro.
