Converting WAV Audio from 25fps to 23.98
tl;dr – How can you convert audio from 25fps to 23.98?
Hey guys! Need some help here! I recently edited my first feature film, and (of course) a few things went wrong. Firstly, I tried to convert everything to ProRes HQ in 23.98, but the computer couldn’t handle it, so I just converted a bunch of the footage to ProRes LT until we export. I made the mistake of converting it at 24fps instead, but I don’t think that’s actually the issue here. We realized that the WAV audio files (for some odd reason) was recorded at PAL rates, you can see it says 25fps if you open the settings in FCP. This was realized when attempting to export the film resulted in audio being out of sync and looking for what the problem could be. I read that technically audio has a sample rate, not a frame rate, but it says the TC Rate is 25 in FCP, and that’s PAL , so I do think that’s our problem. Now I’m trying to convert it to 23.98 in a few different programs, but there were problems, and it can’t output in .WAV anyway, so I wanted to post here and ask if there’s an ‘easy’ way to do this? Any help would be greatly appreciated! Thanks!
