Activity Forums Adobe After Effects converting .VOB and using in AE
  • converting .VOB and using in AE
    Posted by Michael Duff on September 8, 2005 at 8:25 am
    Hi guys,
    I read on another forum (i think the premiere one) that if you rename a .VOB to .MPG you can use it. Now….I know there is normally encrypting and stuff to get through. But because it is a home video I thought I’d give it a go…..And it seems to work. Sort of. It plays OK in AE, but when I render or RAM preview it comes up super jerky.
    Is it even possible to do it this way? or should I convert the files properly?
    Cheers
    Joe Chao replied 21 years ago 2 Members · 1 Reply
  • Joe Chao
    September 8, 2005 at 8:59 am
    Check your settedings of “fields and pulldown”.If you had did it properly.Maybe it’s because that AE can not work well with the vob files.So you might need some certain soft to convert the vob files into avi files before editing them.
    Have you tried the software vob2avi?This soft can convert your vob files into avi files.Then you can edit them in your AE.
