Activity Forums Apple Final Cut Pro Legacy Converting video_TS files to quicktime?
  • Converting video_TS files to quicktime?
    Posted by Jc on May 5, 2005 at 7:30 pm
    I have a Sony DCR-DVD100 video camera and am trying to edit some things I recorded but b/c of the DVD format, nothing can read it. Is there a program that will convert it into something workable?
    Spakuloid replied 21 years, 4 months ago 7 Members · 9 Replies
  • 9 Replies
  • Colin Williams
    May 5, 2005 at 7:45 pm
    JC,
    As far as I know, the TS file is strictly formatted for DVD playback. There may be some crazy software out there that can convert it, but I’ve tried the same thing and came up empty-handed. See if you can create a disk image from Disk Utility and import the contents directly into FCP (assuming that is what you’re using as an NLE), but audio may be another issue. Unless you can find some “Ripping” software. That’s always a gamble and can get messy depending on the length (filesize).
    Hope this helps any.
    Cheers,
    Colin Williams
    https://www.pensivecrow.com
  • Johnsellman
    May 5, 2005 at 7:55 pm
    https://home.comcast.net/~appleguru/dvdrip.html
    Read this. You don’t need to follow all the steps. You will be able to convert the video TS to quicktime with good results. I’ve done it numerous times and used the files with different applications.
  • Jc
    May 5, 2005 at 8:12 pm
    cool, thanks. Which steps do I skip, there’s a bunch…? And when it’s converted, is there a seperate quicktime movie for each chapter from the DVD?
  • Johan Skaneby
    May 5, 2005 at 8:32 pm
  • Nick Brenner
    May 5, 2005 at 10:30 pm
    There’s also a program called cinematize that works very well. Can convert to DV or DVC50 or even uncompressed.
    docofilms PAL 25fps
  • Spakuloid
    May 5, 2005 at 10:41 pm
    Why not just bypass all that and play your DVD through whatever firewire device you have into FCP?
    -Spak
  • Jc
    May 5, 2005 at 10:48 pm
    1: my camera has no firewire out. I’m looking for a new camera now…
    2: I don’t have FCP yet, I just posted in this forum b/c I figured someone here would know (plus someone said I should). I’m just getting into video editing, so I’m trying to learn as much as I can.
  • Peter Mcauley
    May 6, 2005 at 12:55 pm
    I’ve been using DVDxDVPro with great sucess. The pro version enables you to convert to all your favourite codecs.
    https://www.dvdxdv.com/
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Spakuloid
    May 7, 2005 at 7:07 am
    I just bought DVDxDV Pro based on the last post. Hot damn that is a cool little app!!! This will cut my digitizing time on client projects in HALF. A rare find for $80.
    Thanks!! Editing on FCP since 1.5 and still – I learn something new here at the Cow every day.
    -Spak
