Activity Forums Apple Final Cut Pro Legacy converting to work with the Alpha of a .eps (RGB) picture file
  • converting to work with the Alpha of a .eps (RGB) picture file
    Posted by Jason Noto on April 4, 2007 at 5:47 pm
    Can anyone tell me what format I can convert a .eps (RGB) picture file into, in order to work with and seperate the Alpha channel in FCP 5.02? As is, the .eps (RGB) file is unrecognized by FCP.
    I am using Graphic Converter software to make the conversion changes.
    Thanks. I appreciate any insight and info you are able to share
    Jason
    Eric Peterson replied 19 years, 5 months ago 3 Members · 2 Replies
  • Rafael Amador
    April 4, 2007 at 6:03 pm
    Hi Jason,
    I think you can export it as Tiff or PNG or Ps. They support Alpha channel and you can open them in FC.
    Rafael
  • Eric Peterson
    April 4, 2007 at 7:11 pm
    PICT, TGA or BMP
