Activity › Forums › Apple Final Cut Pro Legacy › Converting to set spec list
Samantha Steiner
March 18, 2010 at 6:24 pmWow thanks Andy. I went ahead and tried it out. It saves as .mov is that okay? I thought MPEG2 saved as like m2v or something crazy like that. Also is there a way to to check to make sure all the specs are correct? It really didn’t give me an option to customize. If its not right then it will be rejected and bad things will happen so I just want to be 100% sure its correct.
Thank you guys, you are all very knowledgeable and I appreciate you all helping me thru this confusing task of mine.
