Activity Forums DaVinci Resolve Converting to quicktime file is 30,000 fps?
  • Converting to quicktime file is 30,000 fps?
    Posted by Dustin Moore on July 4, 2012 at 3:42 pm
    I have a 30 second 1080i DNxHD mxf file that I
    would like to convert to quicktime cineform yuv 10 bit.
    If I right click on the file in Browse|Clip details and hit
    convert file with that format, I get a file that
    is unplayable in Quicktime, Vegas or anything else I
    can find.
    Mediainfo tells me that the file has a frame rate of
    30,000 fps. I’ve included the output later in the post.
    The file is about 8 times larger in GB than I think it
    should be.
    My config panel looks this this: https://i.imgur.com/Pn51j.jpg
    Mediainfo output:
    General
    Complete name : F:shitkittensQuickTimeCapture0001V.mov
    Format : QuickTime
    Format/Info : Original Apple specifications
    File size : 9.20 GiB
    Duration : 60ms
    Overall bit rate : 0 bps
    Encoded date : UTC 2012-07-04 16:31:46
    Tagged date : UTC 2012-07-04 16:35:15
    Writing library : Apple QuickTime
    Video
    Format : CineForm
    Codec ID : CFHD
    Codec ID/Info : CineForm High-Definition (HD) wavelet codec
    Duration : 60ms
    Bit rate mode : Constant
    Bit rate : 0 bps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 30 000.000 fps
    Scan type : Progressive
    Bits/(Pixel*Frame) : 21.337
    Stream size : 9.20 GiB (100%)
    Language : English
    Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
    Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
    Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
    Menu
    Duration : 60ms
    Language : English
    Encoded date : UTC 2012-07-04 16:35:15
    View post on imgur.com
    Dustin Moore replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
