Activity Forums Apple Final Cut Pro Legacy Converting To Mpeg Video
  • Converting To Mpeg Video
    Posted by Tyson Caldwell on April 5, 2013 at 3:10 pm
    Hello,
    I have been given a list of specs by a client that I haven’t been able to quite get specific enough in exporting from FCP 7 to Compressor 3.5.3. I’ve tried sending to Compressor from the Final Cut sequence and I’ve tried exporting a QT movie and importing it into Compressor. In a nutshell it needs to be a MPEG 2 Transport Streem, MPEG 2 Long GOP. Constant Bit Rate. I think I’ve figured out most everything except how to set the Video ID (481) and Audio ID (482). And how to set the Format Profile: Main@Main. Is there a way to find these in Compressor/FCP or is there a 3rd party software that would be better for encoding to mpeg? I’ve tried Mpeg Streamclip, MacX Video Converter and iMedia Coverter Deluxe and can’t find all the settings I need in those either.
    Here’s the client’s full list of specs. When I thought I met these, the test file was rejected for the items mentioned above (Video Profile, Video ID and Audio ID):
    Aspect Ratio (4:3)
    Codec MPEG 2 Long GOP
    Container MPEG 2 Transport Stream
    Horizontal 640
    Vertical 480
    Video Bit Rate 8-20 Mbps CBR
    Audio Codec AC3 (2 Ch)
    Audio Sample Rate 48KHz
    Frame Rate 29.97
    Color Sampling 4:2:0
    I’m on OS 10.6.8 on a Mac Pro 2.4 GHz Quad-Core if that matters.
    Thank you in advance for any input!
    Tyson Caldwell replied 13 years, 1 month ago 2 Members · 2 Replies
  • Rafael Amador
    April 5, 2013 at 4:27 pm
    Compressor will make Transport Stream only with embed MP1 audio.
    You need something like Telestream’s “Episode”, or Sorenson Squeeze.
    rafael
  • Tyson Caldwell
    April 5, 2013 at 6:03 pm
    Thanks Rafael!
