Activity Forums Apple Final Cut Pro Legacy Converting timeline format?
  • Converting timeline format?
    Posted by Henry Zektser on August 12, 2005 at 2:42 pm
    Hello all,
    I have a sequence that’s composed of a bunch of DV clips captured directly from the DVCam in FCP.. I have this sequence dropped on a second sequence, so that I can apply some filters across the board. I need to set this second sequence to be uncompressed 4:2:2 or 4:4:4… I can’t figure out how this is done — can someone point me in the right direction?
    Thanks all!
    H
    Jerry Hofmann replied 21 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 13, 2005 at 1:47 am
    You can place the DV sequence in an uncompressed 8 bit sequence, and render it all… Just create a new sequence which is Apple’s uncompressed 8 bit.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
