Activity Forums VEGAS Pro Converting Standard Def to use with 1440 HDV Footage
  • Converting Standard Def to use with 1440 HDV Footage
    Posted by August Taconi on January 3, 2014 at 3:03 am
    I’ve added some standard definition 720×480 24 frame video to a project with 1440 x 1080 60i video. I’ve completed the edit and rendered to DVD however the standard def video has a jerky movement.
    Any suggestions on how I can resolve the problem and get a smoother
    look to the SD Footage. I’d like to render the final project to standard DVD and mp4.
    August
    John Rofrano replied 12 years, 8 months ago 2 Members · 1 Reply
  • John Rofrano
    January 4, 2014 at 11:40 pm
    [August Taconi] “I’ve completed the edit and rendered to DVD however the standard def video has a jerky movement.”
    Since the SD video is 24p check to make sure that you did not disable resampling. i.e., right-click the event and look in Properties and make sure Smart Resample is selected. That’s the only thing I can think of that would cause 24p to stutter.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
