Activity › Forums › Adobe After Effects Expressions › Converting source text to a money format (eg: 603187 to $603,187)
Posted by Ryan Fannon on April 15, 2008 at 3:23 pmNot sure if this is even possible, but I have a source text layer tied to a slider control. I would like to convert the source text from 603187 to a money format of $603,187.
Any ideas?
Ryan
Jason Leaver replied 16 years, 7 months ago 3 Members · 3 Replies -
Mike Clasby
April 15, 2008 at 4:02 pmIf you put this Dan Ebberts expression on the Source Text, then mask off the two zeros to the right of the decimal, I think that’s got it. (Copy the expression, Alt-click the Source Text Stopwatch, Paste, click outside the box)
numDecimals = 2;
commas = true;
dollarSign = true;
beginCount = 603187;
endCount = 603187;
dur = 4;t = time – inPoint;
s = linear (t, 0, dur, beginCount, endCount).toFixed(numDecimals);prefix = “”;
if (s[0] == “-“){
prefix = “-“;
s = s.substr(1);
if(dollarSign) prefix += “$”;if (commas){
decimals = “”;
if (numDecimals > 0){
decimals = s.substr(-(numDecimals + 1));
s = s.substr(0,s.length – (numDecimals + 1));
outStr = s.substr(-s.length, (s.length-1)%3 +1);
for (i = Math.floor((s.length-1)/3); i > 0; i–){
outStr += “,” + s.substr(-i*3,3);
prefix + outStr + decimals;
}else{
prefix + s;
}His expression is very flexible and from here:
https://www.motionscript.com/design-guide/counter.html
Ryan Fannon
April 15, 2008 at 4:08 pmCool. It works great.
I replaced the beginCount and endCount numbers with a slider variable. I just pickwhipped the slider. Now the numbers can be animated and the format stays.
Jason Leaver
January 17, 2010 at 7:22 pmThis is really handy – but would be even greater is if a Slider Control could be used so the numbers could be controled by keyframe. I can’t for the life of me figure it out. I tried the following but I’m getting an error. An ideas?
numDecimals = 2;
commas = true;
dollarSign = true;
beginCount = -1999;
endCount = 1999;
dur = 4;t = time - inPoint;
s = effect("Counter Control")("Slider").toFixed(numDecimals);prefix = "";
if (s[0] == "-"){
prefix = "-";
s = s.substr(1);
if(dollarSign) prefix += "$";if (commas){
decimals = "";
s = s.substr(0,s.length - (numDecimals + 1));
for (i = Math.floor((s.length-1)/3); i > 0; i--){
outStr += "," + s.substr(-i*3,3);
}else{
prefix + s;
