Activity Forums Adobe After Effects Expressions Converting rotation orders – X>Y>Z to Y>X>Z
  • Converting rotation orders – X>Y>Z to Y>X>Z
    Posted by Jamie Bradshaw on April 8, 2011 at 5:25 pm
    This is a follow up to this thread…
    https://forums.creativecow.net/thread/227/17971
    … I thought I’d start a new one as I’ve managed to isolate the problem to a rotation order issue.
    Basically I am looking for a function that could convert the rotation order of X>Y>Z to Y>X>Z.
    I tried to workaround this be creating a parented structure to force a Y>X>Z order but unfortunately this caused massive problems with other parts of the composition.
    I have been struggling through this problem for ages and I am close to losing my mind. If anyone could help I would be so grateful, especially as I am beginning to get quite a bit of pressure from the client now.
    I guess I am looking for an expression that looks something like this:
    camL = thisComp.layer(“Camera 1”);
    x1 = camL.xRotation;
    y1 = camL.yRotation;
    z1 = camL.zRotation;
    rot1 = [x1, y1, z1];
    convertXYZtoYXZ(rot1);
    function convertXYZtoYXZ(r1) {
    // clever maths code here
    return([pan, tilt, roll]);
    Many thanks,
    Jamie
    JimJam•Graphics
    https://www.jimjamgraphics.com/
    Daniel Crooks replied 15 years, 4 months ago 3 Members · 4 Replies
  • Dan Ebberts
    April 9, 2011 at 12:26 am
    It’s definitely possible, but I think it’s going to involve some pretty complex math. I think you’re going to need a rotation matrix to unroll the x,y,z rotation and then another to roll it in y,x,z order. Even if you’re familiar with matrix math, it’s probably going to take quite a bit of work to get it right.
    Dan
  • Jamie Bradshaw
    April 9, 2011 at 2:41 pm
    Cheers Dan.
    I suspected that it might be something along those lines. I’ve found this documentation:
    https://www.geometrictools.com/Documentation/EulerAngles.pdf
    …and I’m hoping I can work out what’s needed from there. Wish me luck!
    Jamie
    JimJam•Graphics
  • Dan Ebberts
    April 9, 2011 at 4:48 pm
    That looks like a very nice resource. I think you just need to rotate -z,-y,-x,y,x,z. You need to make sure that the “handedness” of the rotation matrices matches AE, which I think is a right-handed coordinate system. The devil is in the details though. Please report back if you crack it or get stuck somewhere.
    Dan
  • Daniel Crooks
    April 9, 2011 at 11:16 pm
    hi Jamie
    I’d be very keen to hear if you crack the problem
    I’m struggling with something similar.
    I want to convert the orientation values of an AE camera back into traditional “pan & tilt” values.
    cheers../Daniel
