Activity Forums Apple Final Cut Pro Legacy Converting Quicktime VR files anyone?
  • Converting Quicktime VR files anyone?
    Posted by Harrison Gruber on August 16, 2012 at 3:14 am
    Hello All,
    So I am trying to use a video in final cut pro that has the codec:
    Quicktime VR, VR Panorama, Photo – JPEG, Sprite
    But when I imported it into FCP 7, naturally it played back as a still. I tried transcoding it in mpeg streamclip and compressor but nothing seemed to work.
    It plays back normally in Quicktime 7 (as a moving panoramic shot).
    Here is where I downloaded the QT VR Panoramic from:
    https://www.shakespearesglobe.com/about-us/virtual-tour/upper-gallery
    I tried downloading both , Save as Source and Save as Quicktime.
    I’m out of ideas. Does anyone know of a good way to convert this?
    Enid Rhee replied 9 years, 8 months ago 4 Members · 6 Replies
  • Shane Ross
    August 16, 2012 at 3:22 am
    It isn’t a movie. It’s a still. That’s why it’s showing up as a still. Yes, it is a moving panorama, but a QT VR is basically one large still…stitched together from a bunch of stills, that you can pan and zoom…move. It isn’t video. That’s why all the normal tools that deal with video don’t work on it.
    Shane
    Little Frog Post
  • Harrison Gruber
    August 16, 2012 at 3:33 am
    Any good ideas of how to turn it into a video?
  • Shane Ross
    August 16, 2012 at 3:41 am
    Get screen capture software like Screenflow or SnapzPro…make it go full screen. Record the move, export that to QT…into an editing codec like ProRes.
    Shane
    Little Frog Post
  • Anna Ingenthron
    August 23, 2012 at 12:44 am
    You can also animate the move in After Effects or FCP or Motion.
  • Enid Rhee
    December 13, 2016 at 7:13 am
    Here is a VR video converter that works well on any VR videos downloaded from different sources. If you need to convert VR video to/from common video format like MP4, you can give it a try. Here is a detail guide: Best VR Video Converter for Converting Virtual Reality Videos
  • Enid Rhee
    December 13, 2016 at 7:15 am
    Step 1. Add file to this program
    Step 2. Choose output format and output folder
    Step 3. Start Virtual Reality Video Conversion
    https://www.videos-converter.net/tutorials/vr-video-converter.html
