Activity Forums Adobe Photoshop converting PSD to a PDF file
  • converting PSD to a PDF file
    Posted by Cesar on April 6, 2005 at 8:59 pm
    How do i convert a PSD file to a PDF? Is it as simple as just changing the file type when i save it or is there more to it.
    David replied 21 years, 5 months ago 3 Members · 2 Replies
  • Jeff Cochran
    April 6, 2005 at 9:07 pm
    Cesar
    It really is pretty easy to create your PDF file
    First, save the file out of Photoshop as a PDF, Now, if you double click on the file, it will open in Photoshop. So, what I do to make sure another user can open the PDF in Acrobat with out any trouble is, open Acrobat and use the OPEN command to open the file. SAVE AS and write over the original file. Now if you double click on the file, it will open Acrobat.
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • David
    April 7, 2005 at 6:18 am
    As Jeff said this is easy. However, what do you want to do with the PDF:
