Activity Forums Adobe After Effects converting properties to markers
  • Philippe Cuccu
    December 14, 2009 at 1:59 pm
    In case this is useful for others here’s what I’ve found:
    I’ve edited the jsx file located in the scripts folder located under (on a PC):
    C:\Program Files (x86)\Adobe\Adobe After Effects CS4\Support Files\Scripts\Convert Selected Properties to Markers.jsx
    then open it with any editor like notepad++
    and you just have to edit line 48, juste replace this
    existingMarker.cuePointName = time;
    by this
    existingMarker.cuePointName = existingMarker.cuePointName;
    the save it and you just have to create the first marker, edit it and named it as you wish then select the property(ies) you wish and run the script, so now the markers appears with the little black squares in it and all of them are named like the first one. so flash will recognize the parameters as cuepoints.
    hope this is clear enough, if you need the file modified here it is https://rapidshare.com/files/320732499/Convert_Selected_Properties_to_Markers.jsx.html
  • Todd Kopriva
    December 14, 2009 at 4:52 pm
    Have you applied the After Effects CS4 (9.0.2) update? I think that this script was fixed in that update.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Philippe Cuccu
    December 15, 2009 at 9:37 am
    Hi Todd, and thx for replying so fast.
    I actually have version 9.0.2.42 installed but it seems it’s not the updated version of the script. I don’t know why. editing it solved the problem but I don’t know if it’s the best way to edit it, like I did, I’m not a dev.
