Activity › Forums › Apple Final Cut Pro Legacy › Converting problems
  • Converting problems
    Posted by Jose Fuentes on July 30, 2011 at 2:00 am
    hi everyone, I just finished a project on FCP7 and is playing good on .MOV format. its is a 2GB file so I convert my file to a .MP4 format to make it smaller for upload it to youtube. After conversion, it looks very choppy, even lose sync with audio, the audio is fine, just a video problem. I used ProRes222, and the default settings for to export my project in HD.
    Thanks a lot for reading and helping.
    Jose Fuentes replied 15 years, 2 months ago 2 Members · 2 Replies
  • Chris Tompkins
    July 30, 2011 at 2:06 pm
    What did you use for creating mp4?
    Fully render sequence.
    Export using “Current Settings”
    Drop file into compression program.
    Create “you-tube” optimized file for upload.
    Chris Tompkins
    Video Atlanta LLC
  • Jose Fuentes
    July 30, 2011 at 6:32 pm
    Im using wondershare video converter, I made some tests and after converting my video to .mov (smaller file) it played perfect… Any idea why hd mp4 is causing troubles??
