Activity Forums Apple Final Cut Pro Legacy Converting Premiere Batch Import Data
  • Converting Premiere Batch Import Data
    Posted by Buddamint on August 6, 2007 at 4:59 pm
    have a question;
    I have batch lists from Premiere Pro in .CSV format with the timecode written as following;
    00;00;16;15 00;00;39;03
    semi colons are used by Premiere, where FCP needs colons (00:00:16:15). Does anyone know how exactly to reformat these in a spreadsheet ? I’ve tried reformatting in OpenOffice… no luck yet.
    thanks.
    Buddamint replied 19 years, 1 month ago 3 Members · 5 Replies
  • Stace Carter
    August 6, 2007 at 5:15 pm
    I do this all the time in Excel, just Find and Replace (CTRL+F or perhaps Apple+F).
    You may even be able to do this in one of the various text editors.
    Be careful on how you save out the resulting file though – one little extra space at the beginning or end can wig out your editing app.
    Good luck,
    S
  • Buddamint
    August 6, 2007 at 5:20 pm
    thanks !
  • David Heidelberger
    August 6, 2007 at 5:27 pm
    Also, be sure to keep the final semi-colon before the frame number, otherwise Final Cut will probably think you’re doing NDF TC.
  • Buddamint
    August 6, 2007 at 8:56 pm
    Thanks.
    Here is an example of the file–
    Name Media Start Media End Reel
    S10 01 00:31:16:14 00:33:02:09 tape 18
    The columns are seperated with tabs. It was saved as .csv and I changed it to .txt manually to import. It looks correct as per page 301 of the FCP manual, but FCP is still giving errors about not matching headers.
  • Buddamint
    August 8, 2007 at 4:30 am
    just so anyone doesn’t pull their hair out doing this…
    you have to export the batch as .csv from premiere. then go into a spreadsheet, reformat the headers as shown earlier. then save it as tab delimited (not comma seperated). then, reopen it in a word processor and save it as encrypted text– simple text files do not import.
