Activity Forums Apple Final Cut Pro Legacy Converting PAL to NTSC
  • Converting PAL to NTSC
    Posted by Lawrence Vaughan
    on October 4, 2011 at 5:23 pm
    I have looked on here already and can only find results for After Effects. I have a project, filmed and edited in PAL and have a request for a DVD copy for play back in the USA.
    Is it a case of changing the frame rate on export, then burning an NTSC disc in iDVD / Encore? Or, do I need to do something with the footage?
    Lawrence Vaughan
    replied 14 years, 11 months ago
    2 Members · 2 Replies
  • Neil Patience
    October 4, 2011 at 7:39 pm
    Hi Lawrence
    If you only require a DVD you could try using something like the Nattress plug in.
    https://www.nattress.com/Products/standardsconversion/standardsconversion.htm
    It works pretty well but it does have some limitations and could be a long render.
    I have used it on short clips and odd shots and for that it can be a life saver. Never tried it on anything longform – others may have experience of that.
    To be honest the only proper way to do this is by using a hardware standards convertor, certainly if you were supplying something for broadcast, I would be looking at using something like Alchemist PHC
    best wishes
    Neil
    http://www.patience.tv
  • Lawrence Vaughan
    October 5, 2011 at 6:50 pm
    thanks for your help. I’ll see what the results are like. The DVD I’m converting is just under an hour. This may be unsuitable…
