Activity Forums Broadcasting Converting PAL to NTSC timecode
  • Converting PAL to NTSC timecode
    Posted by Sam Cole on October 20, 2011 at 11:29 pm
    I have a big job to convert a whole bunch of programs from Digibeta PAL to digibeta NTSC.
    I have a DVWA500 PAL and a DVWA500 NTSC deck and a Vistek Vega SD Standards Converter.
    What do I use to convert the timecode so as picture start on the NTSC copy starts the same as the PAL master?
    If I had the time I could write a little program to do the conversion thru a PC using the sound card but its been a while since I have done software.
    Anyone know of any existing software or recommend a box?
    Maybe the Standards Converter can do it already???
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
    Mark Spano replied 14 years, 10 months ago 2 Members · 1 Reply
  • Mark Spano
    October 21, 2011 at 4:25 pm
    Usually converters like this will convert TC as well, but on VITC only. Set your record deck to look at VITC and make sure player deck is not blanking VITC lines and the converter should do the job. I’m pretty sure the Teranex Mini does this, so I don’t see why yours wouldn’t either.
