Activity › Forums › Compression Techniques › Converting PAL to NTSC in FCP, Compressor or iDVD?
  • Converting PAL to NTSC in FCP, Compressor or iDVD?
    Posted by Geoff Bell on June 19, 2012 at 11:52 am
    Hi guys,
    I’m currently editing some PAL footage from a Canon DSLR which has been compressed into an Apple Prores which measures 1920 x 1080.
    I need to put my finished project on a DVD so it to play in the US.
    Should I export to NTSC in FCP, Compressor or simply setup iDVD as an NTSC project and hope that dropping my completed PAL is converted into NTSC?
    What are my options to convert my PAL footage into NTSC and at what stage should I do it?
    Finally what NTSC video format would be ideal for HD video on DVD?
    Thanks in advance!
    Eric Strand replied 14 years, 3 months ago 2 Members · 1 Reply
  • Eric Strand
    June 21, 2012 at 2:11 am
    Use Apple Compressor. You should transcode before editing and keep it in ProRes.
    [Geoff Bell] ” Finally what NTSC video format would be ideal for HD video on DVD?”
    All DVD’s are SD. If you want HD you have to author a Blu-Ray disc.
