Activity Forums Apple Final Cut Pro Legacy converting pal mpeg into ntsc quicktime to import into FCP
  • converting pal mpeg into ntsc quicktime to import into FCP
    Posted by George Felton on March 6, 2009 at 5:45 pm
    Help!
    I got an mpeg from a friend, sent to me in PAL. At least it seems that way because in trying to burn it to dvd, it kept wanting to go to PAL. Even when I flipped into a quick time, and tried burning it that way, it kept coming up PAL. 2 questions: how can I convert it to NTSC so taht i can output a DVD of just that material, and 2) can FCP convert it to NTSC if I dump it onto the timeline as a PAL quicktime? I hope the questions make sense.
    thanks!
    John Calderwood replied 17 years, 3 months ago 3 Members · 2 Replies
  • Rafael Amador
    March 7, 2009 at 1:13 am
    You should try first to convert to mpg to a PAl .mov, then that one to an NTSC.mov.
    You can try to do all at once with MPGStreamclip.
    Rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • John Calderwood
    May 7, 2009 at 10:14 pm
    I am trying to get footage from my DCR-SR85 into a FCP compatible form. They appear as MPG files, and when I convert them to MOV or DV they are very low quality. Any suggestions?
