Activity Forums Apple Final Cut Pro Legacy Converting P2 to SD 10-bit with Compressor
  • Converting P2 to SD 10-bit with Compressor
    Posted by Todd Beabout on March 23, 2007 at 5:00 pm
    I am trying to convert some DVCProHD footage from a P2 card into SD 10-bit uncompressed. When I do this in Compressor using the “Advanced Format Conversion” setting, it does not seem to change the frame rate of the footage from 23.97 to 29.97. When I open the converted file in QuickTime, the info panel shows that the frame rate is 29.97, but when I bring it into FCP the framerate is displayed as 23.97 and it requires a render in the timeline.
    I’m just not understanding why Compressor is not converting the frame rate. What should I do in order to edit this footage in a SD 10-bit timeline?
    -Todd Beabout
    Vazda Studios
    Todd Beabout replied 19 years, 5 months ago 1 Member · 1 Reply
  • Todd Beabout
    March 23, 2007 at 8:56 pm
    If you are going to do this, be sure to change the “Frame Controls” to “Custom” or your frame rate will stay the same as the original clip. The “10-bit Uncompressed NTSC” preset defaults to “Frame Controls” of “Automatic”. FYI
    -Todd Beabout
    Vazda Studios
