Activity Forums Adobe Premiere Pro Converting odd framerates
  • Converting odd framerates
    Posted by Scott Allen on August 23, 2013 at 2:06 pm
    We have Super and Regular 8mm home movie footage which was scanned and delivered to us as ProRes 422 files in framerates varying from 16.03 to 17.95 fps. When they’re dropped into a 23.976 sequence in Premiere (on the way to Blu-ray), they seem to look OK.
    I’m not really complaining, I’m just curious to see if anyone knows the actual method by which Premiere Pro does this conversion. I understand the “normal” conversion that occurs with 24fps film to 30/29.97 fps video, but how does THIS work?
    Scott Allen
    sallen@mailbox.sc.edu
    University of South Carolina
    Moving Image Research Collections
    Walter Soyka replied 13 years, 1 month ago 3 Members · 5 Replies
  • Walter Soyka
    August 23, 2013 at 2:52 pm
    By default, Premiere Pro duplicates (or skips) frames to match framerates. You can set a clip to frame blend [link] instead (right-click it and choose “Frame Blend”). This will create new intermediate frames by blending (I think via averaging, or a weighted dissolve) one frame over the other.
    To figure out how the frames are duplicated, we can do a little math.
    Output is 24 fps, Regular 8 is 16 fps. 24 – 16 = 8, so we have to make up 8 frames over 16, or 8/16 = 1/2. Every other clip is duplicated.
    Output is 24 fps, Super 8 is 18 fps. 24 – 18 = 6, so we have to make up 6 frames over 18, or 6/18 = 1/3. Every third frame is duplicated.
    If you step through your footage frame by frame in Premiere, you should see this is true.
    Leaving frame blending off will give a sharper image with more stuttery motion. Turning frame blending on will give a softer image with smoother motion.
    You can get a little fancier with 1080i60 output and custom pulldowns via a free tool called Avisynth. 18p to 60i is a 4:3:3 pulldown. 16p to 60i is usually reconformed down to 15p and then simply frame-doubled.
    Walter Soyka
  • Scott Allen
    August 23, 2013 at 3:04 pm
    So, it sounds like if I’m more concerned about sharpness of the frames, I go with the default frame-duplicating (in this case) – but if I’m more concerned about the “flow” of motion, I go with the frame-blending.
    [Walter Soyka] “You can get a little fancier with 1080i60 output and custom pulldowns via a free tool called Avisynth. 18p to 60i is a 4:3:3 pulldown. 16p to 60i is usually reconformed down to 15p and then simply frame-doubled.”
    How does that tend to affect the look of it as opposed to the less-fancy ways?
    Thanks for the quick response,
    Scott Allen
  • Walter Soyka
    August 23, 2013 at 3:26 pm
    [Scott Allen] “So, it sounds like if I’m more concerned about sharpness of the frames, I go with the default frame-duplicating (in this case) – but if I’m more concerned about the “flow” of motion, I go with the frame-blending.”
    I’d think people would tolerate a little bit of stutter really well with old home movies: it doens’t look like a technical flaw, it looks like nostalgia.
    I’d be inclined to stay away from frame blending myself. Having it off by default is a good thing.
    [Scott Allen] “How does that tend to affect the look of it as opposed to the less-fancy ways?”
    Comparable to 3:2 pulldown for 24p to 60i.
    Wikipedia has good background information on telecine pulldown [link], including information on other pulldown patterns.
    Walter Soyka
  • Robert Bracken
    August 23, 2013 at 6:49 pm
    How do I learn more about pull down? Where can I see some examples?
  • Walter Soyka
    August 24, 2013 at 1:15 pm
    [Robert Bracken] “How do I learn more about pull down?”
    The Wikipedia’s article on telecine has a great explanation of pulldown [link] — the process by which progressive frames from one frame rate are converted to interlaced fields of a different frame rate.
    If you have specific questions, I’d be happy to try to answer.
    [Robert Bracken] “Where can I see some examples?”
    Nearly every film you’ve ever watched on a standard definition television had 3:2 pulldown applied.
    Walter Soyka
