Activity Forums Apple Final Cut Pro Legacy Converting NTSC to PAL
  • Converting NTSC to PAL
    Posted by Russell Scott on November 24, 2006 at 5:52 pm
    I just completed a Workout video project for a client and shipped it off to China for duplication… now they want a PAL version. It was all shot & cut in NTSC.
    I’ve made a test PAL disc and played it in a PAL player & monitor and it worked OK… but I just wanted to drop a line out there and see if anyone has a better way of converting the NTSC to PAL.
    Currently I’m converting the NTSC video in FCP using Compressor PAL settings. I then drop the converted PAL Video into a FCP PAL project and Encode it for DVD using Compressor.
    Is this the best way to convert to PAL for a PAL DVD?
    Thanks for your time!
    Mactrix replied 19 years, 10 months ago 4 Members · 5 Replies
  • Walter Biscardi
    November 24, 2006 at 7:00 pm
    [Russell Scott] “I’ve made a test PAL disc and played it in a PAL player & monitor and it worked OK… but I just wanted to drop a line out there and see if anyone has a better way of converting the NTSC to PAL.”
    Nattress Standards Converter but you need to convert each clip individually. Does not work well on an entire timeline as you will get bad glitches at each cut.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • John Burgan
    November 24, 2006 at 10:16 pm
    [walter biscardi] “Does not work well on an entire timeline as you will get bad glitches at each cut.”
    Export as a QT movie to create a single file before converting…
  • Walter Biscardi
    November 24, 2006 at 10:36 pm
    [John Burgan] “Export as a QT movie to create a single file before converting…”
    I don’t think even Graeme recommends that. He recommends applying the filter to individual clips rather than an export of the entire timeline.
  • Russell Scott
    November 24, 2006 at 11:10 pm
    Perfect!
    Thanks For Your Time Everyone!
    The Cow Rocks!
  • Mactrix
    November 25, 2006 at 9:24 am
    Compressor 2 from Apple can do it as well …
