Activity Forums Web Design (WordPress, Joomla, etc.) converting ntsc .mov to halfsize .flv for the web
  • converting ntsc .mov to halfsize .flv for the web
    Posted by Chris Harvey on July 16, 2006 at 3:37 pm
    greetings. i’m an old school motion graphics designer trying to keep up.
    i want to use AFX to prep my show reel files for the web.
    my web builder is going to convert whatever i give him to .flv
    he says just make them the pixel size i want with lossless compression,
    and he’ll convert them.
    my originals are NTSC DV 720×480 .mov – with stereo audio at 41.100
    a friend recommended shrinking them to iPod video size 320×240,
    but that is a mathematic reduction of a DV Square Pixel size 720×540.
    (i’ve read the CC tutorial on square pixels but it didn’t really tell me
    what i should do in this case)
    should i render my new smaller size comps in SQUARE PIXELS ?
    should i just reduce to half size (360×240) or should i force-fit to 320×240
    or should i crop slightly to 320×240 ?
    should i consider field or non-field render ?
    should i reduce the audio to mono to save bandwidth ?
    another friend recommends Sorenson Squeeze but i am comfortable in AFX.
    Bret Williams replied 20 years, 1 month ago 2 Members · 3 Replies
  • Bret Williams
    July 16, 2006 at 9:06 pm
    [Harvola] “greetings. i’m an old school motion graphics designer trying to keep up.
    another friend recommends Sorenson Squeeze but i am comfortable in AFX.”
    Your friend is right. Render your comp to 320×240. Which if you know your math is the same as 4:3, which IS the same as non-square 720×480, or square 720×534. 720×480 is NON-SQUARE pixels, which can only be shown properly by a television, not computers. Computers only deal with square pixels. So yes, force fit your 720×480 to 320×240. Do not field render as computers don’t play back fields and it will look like mush. I personally think the best way to save bandwidth is to reduce to 15fps AND make it mono. Keep it 16 bit but you can reduce to 22khz or 32khz.
    320×240 is actually 1/4 the size, not half.
  • Chris Harvey
    July 17, 2006 at 4:26 am
    thanks! – but i’m still confused about this:
    should i select SQUARE PIXELS in my comp set-up ?
    (this AFX comp is strictly for generating these files for the website.)
    also: i’m no math whiz, but 320 x 2.25 = 720 and 240 x 2.25 = 540
    …doesn’t that make 320 x 240 the equivalent of 720 x 540 ?
    sorry to be so rudimentary! – this puzzles my very analog mind.
  • Bret Williams
    July 17, 2006 at 4:56 am
    No need to make a comp a particular size. Do it all in the render que.
    Drop your DV file into a DV comp just as normal. On output, simply output at 320×240. Non-field rendered. 15fps. 22khz mono, 16bit, etc.
