Activity › Forums › Adobe Premiere Pro › Converting NTSC foortage to PAL
  • Converting NTSC foortage to PAL
    Posted by Neil Kidney on March 2, 2007 at 6:56 pm
    Is it possible in Prem to convert footage from NTSC to PAL? In a corner at the moment and really need a fix? how do the pros do it for DVD releases?
    ANy help would be very much appreciated!
    Cheers, TBK
    Redgum replied 19 years, 7 months ago 4 Members · 4 Replies
  • Blast1
    March 2, 2007 at 8:57 pm
    Are you going to burn the DVD from Ppro’s “DVD Layout” or Export and use another authoring program?
  • Neil Kidney
    March 3, 2007 at 8:08 pm
    It will be put onto Digi Beta…
  • Aanarav Sareen
    March 4, 2007 at 1:22 am
    [theboykidney] “Is it possible in Prem to convert footage from NTSC to PAL?”
    Premiere Pro does not do a good job. I recommend Canopus Procoder.
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Redgum
    March 4, 2007 at 9:10 am
    And if you’re going to digibeta don’t bother with Procoder either. Pay a little extra and do a proper standards conversion.
    I assume if you’re going to digibeta you intend to broadcast. Even a Procoder conversion won’t pass the test in PAL land.
    From OZ.
    Redgum Television Productions
    Broadcast & Corporate Documentaries
    Brisbane, Australia
