Activity Forums Apple Final Cut Pro Legacy Converting MTS files to ProRes for FCP7
  • Converting MTS files to ProRes for FCP7
    Posted by Bobby Hall on August 2, 2014 at 4:22 am
    I converted some MTS files to ProRes 422 using Pavtube iMedia Converter, and then I remembered that Clipwrap does the same thing, except that it “wraps” MTS files to ProRes with no converting needed. Does converting them the way I did in iMedia Converter result in quality loss or is it no different from using Clipwrap? Thanks.
    Andrew Rendell replied 12 years, 1 month ago 2 Members · 1 Reply
  • Andrew Rendell
    August 2, 2014 at 7:46 am
    You can’t “wrap” a file from one codec to another without converting.
    Whether there is any quality loss when converting between codecs depends on the algorithm used in the conversion process and the data rate. (I’m not in a position to compare the software you mention, sorry).
