Activity › Forums › Apple Final Cut Pro Legacy › converting mts files for use in FCP
Posted by Don Gordoni on June 30, 2010 at 5:15 pmI am using emicsoft mts converter that has two choices for HD video (mpeg 4 and H.264) with a max video bit rate of 15000 kbps. The footage was shot on a Canon VIXIA HF 20. My project settings for FCP are DVCPro HD 960×720.
Recommendations?
Different conversion software?
How do I go about converting or cropping the aspect ratio? Use motion and increase scale, crop?
Should I use the canon software on a PC (no mac version with camera) and see if it will export avi etc.
DonJeremy Garchow replied 14 years, 4 months ago 7 Members · 14 Replies -
Don Gordoni
July 1, 2010 at 3:02 amTried log and transfer but it does not recognize mts files.
Thanks for the suggestion.
Adam Deniston
July 1, 2010 at 3:24 amI’ve had success with converting the MTS files to quicktimes with Toast Titanium, although I’ve heard Adobe Media Encoder works well too.
Adam Deniston
http://www.linkedin.com/in/adamdeniston -
Stuart Davidson
July 1, 2010 at 8:30 amUse ClipWrap or Voltaic to convert the .mts files, both have a small cost attached but are the best solution.
Jason Porthouse
July 1, 2010 at 8:50 amI’ve the same problem – a bunch of .m2ts files send on a DVD. No proper file structure hence L&T wont see it.
I’ve tried ClipWrap, which at least lets me see them in FCP, but can’t seem to get over a field order problem – basically looks like it’s playing the wrong field order, but no amount of playing with shift fields seems to cure it.
Any suggestions would be most appreciated!!
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Don Gordoni
July 1, 2010 at 12:15 pmI believe I have the full structure (the original folder with the info files for Canon, CPI files) but FCP still doesn’t recognize it.
I used the HD MOV settings of 1280×720 and 15,000 Kbps and then placed it on the timeline in a new project. Only the audio had to be rendered in order for it to play.
I’m still trying to figure out the best project settings for preparing HD for broadcast.
Thanks to all.
Jeremy Garchow
July 1, 2010 at 12:28 pmUse compressor and transcode the mts files to 1280×720 ProRes files with 48k 16bit Linear PCM audio. Keep the same frame rate.
Jason Porthouse
July 2, 2010 at 12:22 pmJeremy,
the problem is Compressor won’t even see the files. When I play wrapped files in QT (from clipwrap, either transcoded or wrapped) they exhibit an odd frame effect – not bad interlacing, but a kind of ‘one-forward one-back effect, where each subsequent frame steps back, then forward. It’s very odd, and not something I’ve seen before.
Anyway, it’s proving to be a right royal PITA!!
Jason
Don Gordoni
July 2, 2010 at 2:50 pmEmicsoft is only $41 and works well for what it does but the highest quality settings (unless I’m overlooking something) are not equal to the original mts files. The HD MOV setting has video bit rate setting of 15000 kbps and I used the 1280×720 because it was the closest to the 960×720 settings of my project.
