Activity › Forums › Apple Final Cut Pro Legacy › converting MT2 files for FCP?
Posted by Thomas on December 7, 2007 at 12:36 amCould someone tell me what I need to do? They’re on my drive as MT2 files. FCP won’t let me import.
Thank you!
Thomas
Rafael Amador replied 16 years, 11 months ago 6 Members · 6 Replies -
Herb Tarlek
December 7, 2007 at 2:25 amHi there,
I assume those are HDV files? At any rate, download the awesome freeware “MPEG Streamclip” (grab it from macupdate.com or versiontracker).
Put your M2T in it (you can use the batch list function for multiple clips) and then converts it to whatever you need, or demux to MPEG2/MP2 audio for lossless results (if it IS HDV, that is)..
Jeremy Garchow
December 7, 2007 at 3:48 amTry opening the log and transfer window then add those files to the window. FCP 6.0.2 has added a bunch more support for avchd and hdv.
What camera?
Jeremy
Detlef Villerius
October 14, 2008 at 5:21 pmlog and transfer window should do the trick.
recently i’ve encoutered a whole new problem..
i just to import clips from my sony sr12 into fcp via “log and transfer” but now all of a sudden i get an error message that says:“SONY SR12” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.
don’t understand why exactely but i can’t import clips from my camera anymore..
a clue anyone???
thanks in advance
Chris Whiting
October 30, 2009 at 2:37 amI had a similar problem and are now using MPEG Streamclip, but once i import to FCP i can not unlink the audio files. i want to adjust just one of the audio channels. only problem is with the clips from Streamclip, other clips no problem unlinking.
please help
Rafael Amador
October 30, 2009 at 3:29 am
