Activity Forums Apple Final Cut Pro Legacy Converting movie to a .TS file
  • Converting movie to a .TS file
    Posted by Jon Robinson on June 18, 2009 at 3:55 pm
    does anyone know if it’s possible to convert fcp sequence into a .ts file?Directv is requiring this as their new delivery of content.I won’t bother giving all specs needed until I know that FCP can actually convert to this. Thanks for any help, Jon R
    Adonis Williams replied 17 years, 1 month ago 3 Members · 3 Replies
  • Michael Sacci
    June 18, 2009 at 5:22 pm
    they are probably asking for a transport stream version of mpeg2. This is something that Compressor would encode but without the specs it is all guessing. But even if Compressor cannot you would add to get an encoder that could but it would always be done outside of FCP.
  • Jon Robinson
    June 18, 2009 at 7:45 pm
    This is the spec I need to get from a final cut pro seq
    Table 6: 480i Long Form File Delivery Requirements
    Description Requirement
    MPEG2 Video Size 15mbps CBR
    MPEG2 Transport Stream 18mbps (CBR Transport Stream)
    File Extension .mpg
    Video Resolution 720×480
    GOP Long GOP (GOP size = 30 or 15, P frame distance = 3)
    Chroma Subsampling 4:2:0
    Audio Embedded AC3 (5.1 preferred, 2.0 acceptable)
    Audio Bit rate 192kbps minimum for 2.0, 384kbps for 5.1
    Closed Captioning ATSC or NA DBS Line 21 (EIA608 in a 708 packet)
    PMT PID 0x01E0 (480)
    Mux PID 0x01E1 (481)
    Video PID 0x01E1 (481)
    Audio PID (1st pair) 0x01E2 (482)
    Audio PID (2nd pair) 0x01E3 (483)
    Audio PID (3rd pair) 0x01E4 (484)
    First frame of video 3 seconds after the start of the file (00:00:03)
    Source ID in VANC If possible
    Black/silence video padding 3 seconds at beginning and end
    ***Please note this also needs a closed captioning Packet. This is the preferred output standard we need to have…or they may take this instead:
    Table 11: H264 SD File Delivery Requirements
    Frame rate / Interlaced 29.97
    H264 Video Size 2 Mbps CBR
    MPEG2 Transport Stream 3 Mbps (CBR transport stream)
    File Extension .ts
    Entropy CABAC
    Video Resolution Full raster 720×480
    H264 Profile Main Profile @ Level 3.0
    GOP Long GOP (GOP size = 30 Max, B frame range = 0 min / 3 max)
    Audio AC-3 Dolby Digital audio; stereo or surround sound (5.1 surround sound preferred)
    Audio Bit rate 192 kbps or 384 kbps
    Video PID – includes the PCR 0x01E1 (481)
    Audio PID (2nd pair) optional 0x01E3 (483)
    Audio PID (3rd pair) optional 0x01E4 (484)
    Transport Stream Muxer Conformance ATSC
    Transport Stream Muxer Program Number 1
    PAT & PMT Period 250ms
    Let me know if all this is possible, thanks again, jon
  • Adonis Williams
    August 20, 2009 at 7:09 am
    Hey Jon,
    I am having the same issue. Did you ever figure it out?
    A.W.
