Activity Forums Compression Techniques Converting .mkv movie for DVD
  • Converting .mkv movie for DVD
    Posted by Sean Kapleton on September 4, 2007 at 2:39 pm
    I am trying to convert a .mkv movie on my mac G5 – it is in MKV format (matroska video file). I have only been able to view this movie by using the VLC player which a friend recommended to me as a good all around player which recognizes most formats. Now I am hoping to convert this mkv movie for dvd – i am using dvd studio pro but when i tried bringing it into compressor it did not recognize the file format in order to convert it into MMPEG2 & aac.
    I am hoping to find a good conversion tool for my mac to keep the quality high and create either quicktime mov’s or mpeg & aac – any suggestions people?
    Ideally i would keep the quality at the highest possible for this almost 2 hour movie and then I think worry about compressing it for dvd using Compressor before bringing it into DVDSP.
    Sean Kapleton replied 19 years ago 2 Members · 6 Replies
  • Craig Seeman
    September 4, 2007 at 2:47 pm
    Mac supported Players for .mkv
    https://www.matroska.org/downloads/others.html
    Windows supported Players
    https://www.matroska.org/downloads/windows.html
    Apparently the only tool on the Mac that can extract the file is made by them.
    Look for link next to OS 10.4
    https://www.bunkus.org/videotools/mkvtoolnix/downloads.html
  • Craig Seeman
    September 4, 2007 at 2:53 pm
    And you might want to check this out on Version Tracker. I find the Feedback/Comments reports entertaining and informative.
    https://www.versiontracker.com/dyn/moreinfo/macosx/23606
  • Sean Kapleton
    September 4, 2007 at 5:36 pm
    ok great thank you so much for taking the time to try to help me out – i will look into this stuff.
    best
    BK
  • Sean Kapleton
    September 4, 2007 at 6:10 pm
    So i downloaded this thing called “MKVTOOLNIX 2” and i am totally lost now on this interface and how to make either .mov’x and / or mpeg2 & aac – ultimately i just want to burn this 2 hour mkv format movie using dvd sp or toast but it seems very complicated…any other advice?
    thank you
  • Craig Seeman
    September 4, 2007 at 6:31 pm
    Only thing I see resembling a tutorial
    https://www.dvd-guides.com/content/view/157/59/
    If you’ve read the Version Tracker comments or the ones under this tutorial, you’re not the only one who’s frustrated.
    If this is for a client, I’d charge them for the research! Someone handed you something in which only the codec developers has tools to work with it and their tools don’t seem well supported or documented.
  • Sean Kapleton
    September 4, 2007 at 7:42 pm
    I also just tried this app – MoKgVm2DVD which makes .avi & ac3 but which dont seem to play / open in quicktime – i though i had it but alas no luck – unfortunately its for a personal project so i cant bill thw research and work – thanks again for your time and help – you rock
    best
    Bk
