Activity Forums Compression Techniques Converting .m2t to MXF with Sorenson 11
  • Converting .m2t to MXF with Sorenson 11
    Posted by Seth Robinson on September 16, 2016 at 4:27 pm
    Hello,
    I am new here and have mild-moderate experience with conversion software. I don’t understand too much of the engineering behind it but respect it.
    I am attempting to convert a .m2t file our Leightronix UltraNexus created into an MXF with Sorenson Desktop 11. The process seems to work until I get it into AVID and I have an audio sync issue. It seems the longer the video goes the further the audio gets delayed.
    I notice the source audio is AAC and Sorenson is trying to turn it into LPCM. I am not too familiar but am wondering if there is some padding issue going on here?
    Let me know if you have any ideas or if you need any more information. Thanks.
    Computer – Windows
    Operating system including exact version number: Windows 7 SP1
    Software used including version number: Sorenson 11.0.0.185, Avid Media Composer 8.5.0.41065
    Source codec (file you put in): .m2t
    Destination codec (file you want out): .mxf
    Type of destination use: edit for DVD.
    Craig Seeman replied 10 years ago 2 Members · 1 Reply
  • Craig Seeman
    September 20, 2016 at 9:02 pm
    I believe LPCM at 48kHz should be OK. Check the sample rate. Also check the frame rate to make sure something odd didn’t happen. The free version of Telestream Stream Switch is good for inspecting files.
