Activity Forums Apple Final Cut Pro Legacy converting logo to alpha channels + animation for video
  • converting logo to alpha channels + animation for video
    Posted by Ninetynine on July 7, 2006 at 7:43 am
    Yeah!!! I can finally log on to Creative Cow! I’ve missed so much!
    To the point: I need to convert a logo into a video. I’d like to be able to change the shape so that it appears animated and I’d like to make it have Alpha channels so that I can use it as an overlay. (If I’m totally washed up in my thinking — I’m cringing already, but I would appreciate any and all advice.
    Previously, I’ve had problems with pixelation and transparency.
    The logo was created in Illustrator by another designer. I think that I could get a copy of it from him, but I’m not even sure what file format would work best.
    I’ve not yet purchased the Newest After Effects — do I need it?
    Thank you in advance to all that reply!
    Yours,
    Ninetynine
    ninetynine
    Ninetynine replied 20 years, 2 months ago 3 Members · 5 Replies
  • Bouncing Account needs new email address
    July 7, 2006 at 10:59 am
    I don’t understand what you want to know.
    Do you not know how to select specific areas of an image and create an alpha channel around them?
    You need to be specific with the problems you’ve had so we can be helpful.
  • Ed Dooley
    July 7, 2006 at 2:32 pm
    I don’t know what the logo looks like, or how you want to animate it, but I commonly take
    one of my trade association clients’ logos into Photoshop, break it up into segments (selecting
    or lassoing or magic wanding pieces) then importing them into AE as layers to add movements.
    You could do the same with Ilustrator to FCP or PS to FCP. I usually create a new PS file with transparent
    background in the size I want for video (720×486 usually) and drag the slected chunks of the logo into that new
    file so each chunk is its own layer already.
    Ed
  • Ninetynine
    July 7, 2006 at 3:38 pm
    Thanks for your reply.
    And, uh, no — I don’t know how. (Should I be embarrassed?)
    I know I’ve used “canned” graphics that are in Alpha channel mode (if you will.)
    Specifically, I want to create a transparent area within the logo so that I can use the logo as an overlay.
    The other issue is Pixelation as I resize the object. What file format do I need to have the logo design to be in, so that when I bring it into my Final Cut Pro video it looks sharp, clean etc.
    Thank you again for the reply.
    ninetynine
  • Ninetynine
    July 7, 2006 at 3:48 pm
    Thank you, thank you. I will try this.
    ninety nine
  • Ninetynine
    July 7, 2006 at 3:54 pm
    Thank you very much. I will try your suggestions as well. I truly appreciate the advice.
    ninetynine
