Activity › Forums › Audio › Converting line level to mic level
  • Converting line level to mic level
    Posted by Justin Toney on September 19, 2012 at 4:06 pm
    I have a CANON XH-A1 camera which I am using for shooting football. I’m being sent a line level signal from the radio booth. At the same time, I also have a phantom powered crowd microphone that I am needing to use.
    The XH-A1 only has 1 line/mic option and not separate options for each channel. I need something that will either convert that line level to a mic level (otherwise it is distorted) or something that can bring my phantom powered microphone to line level.
    I’m open to purchase or creating such a contraption, but I would rather make it if I can.
    Jordan Wolf replied 13 years, 11 months ago 4 Members · 5 Replies
  • Eric Toline
    September 19, 2012 at 6:36 pm
    What you need is a 40db pad. It’s available as an inline plug in. The ATT448 from Markertek.com is a 3 step unit with attenuation at 20/30/40db for $15.59. You can’t build one that durable for that price.
    Eric
    “I push the RECORD button and hope for the best”
  • Peter Groom
    September 19, 2012 at 9:01 pm
    Eric is right -40 db pad.
    Peter
    Post Production Dubbing Mixer
  • Justin Toney
    September 21, 2012 at 6:36 pm
    Yea I got an adapter from B&H. Is there a diagram on how to build my own? I would like to make a few of these.
  • Eric Toline
    September 22, 2012 at 2:28 am
    Here’s a simple 20db pad diagram:
    XLR-M pin 1……………………….XLR-F pin 1
    XLR-M pin 2….(470 ohm resistor)……XLR-F pin 2
    XLR-M pin 3….(470 ohm resistor)……XLR-F pin 3
    A 100 ohm resistor between pins 2 & 3 will give you 20db of attenuation. For more attenuation lower the value of the 100 ohm resistor, a 50 ohm should be about right.
    Eric
  • Jordan Wolf
    October 18, 2012 at 5:15 pm
    Make sure that the balanced feed you’re being sent from the radio booth has its Pin 1 lifted, or the phantom power coming from your camera’s inputs could fry the output circuitry in the mixer.
    Wolf
