Activity › Forums › Adobe After Effects › Converting Layers
Converting Layers
Posted by William Wolfman on November 17, 2019 at 1:03 amI am Interested in learning (if it’s possible) to change the type of layer (shape/adjustment/text/solid) into another type?
So, example… You have a shape layer and want to convert it into a solid.
Is this possible? Thanks.
John Williams replied 6 years, 10 months ago 4 Members · 6 Replies -
Eric Santiago
November 17, 2019 at 2:29 amNot sure what you mean can you clarify as to why you want to change it to a Solid?
A solid is basically a null object with the ability to take fill color and mask.
It has pixel size for sizing. -
William Wolfman
November 17, 2019 at 4:08 amIt would be in the case for converting shape layers into solids for the purpose of masking the shape. AE has this behavior where creating shape layers won’t allow you to apply a mask over it. Pre-composing will solve it but their isn’t a solution for making the shape layer respond to masks.
Mervin James
November 17, 2019 at 6:13 am -
William Wolfman
November 17, 2019 at 6:19 am -
John Williams
November 19, 2019 at 10:40 amHi William, are you aware you can actually add masks to Shape Layers?
When you create a shape layer after effects defaults the Pen and Rectangle tools to create more shapes within the layer but to the right of the main tool bar, when you have the pen or rectangle tool selected you can choose ‘Tool Cretes Shape’ or ‘Tool Creates Masks.’
From what it sounds like, this is all you need to do.
However, if you still need the Shape converted to a Solid for some other reason then select the shape and go:
Layer / Auto-Trace, this will create a Solid layer that uses a Mask to recreate the Shape layers shape.Hope that helps.
John Williams
Soho Editors
