Activity Forums Compression Techniques converting HDV to H264 using compressor 3
  • converting HDV to H264 using compressor 3
    Posted by Geo Monterosa on October 14, 2008 at 7:03 pm
    After converting HDV to H264 using the default settings, I opened the movie through Quicktime and the frame was 4×9 instead of letter box frame of original source. I checked the default settings of H264 in compressor and the frame setting is 1440×1080, the same as the original source. Is this normal?
    Daniel Low replied 17 years, 11 months ago 2 Members · 1 Reply
  • Daniel Low
    October 14, 2008 at 9:38 pm
    You don’t say what you want to deliver, or to whom?
    Is it for web delivery, IPTV, Broadcast transmission or mobile device?
    Just so you know, HDV uses non-square pixels to deliver a 16:9 image so 1440×1080 non-square pixels equals 1920×1080 square pixels.
    1440/1080 = 1.333:1 or 4:3 – Rectangular pixels
    1920/1080 = 1.777:1 or 16:9 – Square pixels
    Bottom line is that 1440×1080 is HDV’s way of ‘cheating’ 16:9 Full HD video.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
