Activity Forums Avid Media Composer Converting HDV NTSC to PAL While keeping the same timecode
  • Converting HDV NTSC to PAL While keeping the same timecode
    Posted by Ronen Gur arye on January 4, 2011 at 12:26 am
    hello
    i would like to know if there is a way to convert an hdv clip (shot on canon hv20 ntsc) to pal while saving the original timecode of the ntsc clip
    this is importent becuse when i will go to online,the timecode is critical to be the same
    thanks
    Ronen Gur arye replied 15 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 4, 2011 at 3:12 am
    So you want to convert NTSC to PAL, but refer back to the NTSC clip when you online? YOu can’t do that. If you are going to online in NTSC, keep the footage NTSC. Onlining something that has been cut in a different frame rate is a big hassle.
    Shane
  • Ronen Gur arye
    January 4, 2011 at 7:14 am
    thanx, i did not think that the diffrent frame rates would affect the timecode until u said so….
