Activity Forums Apple Final Cut Pro Legacy Converting from XDCAM HD to HDV
  • Converting from XDCAM HD to HDV
    Posted by Chrome on June 15, 2007 at 12:30 pm
    Hi All,
    I have a project on the timeline done in XDCAM HD and want to export it to my new Sony HDV deck, what is the best way to do the conversion to allow me to save it to the deck and keep the quality up?
    All help appreciated.
    Cheers,
    Chrome
    Mac G5, Dual 2.5, 8Gb, Media G-Raid, 30″ Cinema, Decklink HD Pro, HD-Connect-LE
    Mark Maness replied 19 years, 3 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 15, 2007 at 2:14 pm
    I’d suggest that you export a reference movie to compressor, and use it’s “advanced format conversions” to get the job done.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark Maness
    June 15, 2007 at 8:55 pm
    Easiest thing to do is to create a new sequence in HDV and drop your XDCAM HD sequence into it, then render. After that, you can just “Print to Tape” like normal.
    BUT first, let me ask… is the footage shot XDCAM HD SP (25 mbit)? If so, its already HDV. If its XDCAM HD HQ (35 mbit), then you have to do the conversion I just spoke of.
    I’ve done this many times without quality loss.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
