Activity Forums Adobe Photoshop Converting from RGB to CMYK
  • Converting from RGB to CMYK
    Posted by Riccardo Sinti on August 25, 2005 at 3:05 pm
    When I convert from RGB to CMYK my colors are getting duller, less saturated.
    What can I do so that my colors remain the same?
    When I color pick one of the colors in RGB and look at the value in CMYK sliders I get the little exclamation point in the corner.
    Is this impossible for certain colors?
    Jonathan Decker replied 21 years ago 3 Members · 2 Replies
  • Richard Harrington
    August 25, 2005 at 3:22 pm
    YUP
    Work with colors that are in both color spaces….
    Means that color won’t work
    Yep.. additive versus subtractive color space…. suggest doing some in-depth reading if you are working in professional output.
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Jonathan Decker
    August 27, 2005 at 2:57 am
    Bust out the levels for the cmyk.
    I work in rgb for video, and cmyk for our press work. If you want a frame of RGB to match CMYK as close as possible you have to manipulate the color levels in CMYK by hand. It comes down to best visual match, instead of color by number.
    good luck.
    gesamtkunstzwerk
