Activity Forums Adobe Premiere Pro Converting from Anamorphic HD to a square PAR?
  • Converting from Anamorphic HD to a square PAR?
    Posted by Zack Yoshyaro on November 8, 2011 at 6:10 pm
    I have two pieces of footage that I’m trying to use in the same project. One was shot with a 1.333 PAR and the other with square pixels. How would I go about converting one to square..?
    Zack Yoshyaro replied 14 years, 10 months ago 2 Members · 2 Replies
  • Jeff Pulera
    November 8, 2011 at 6:51 pm
    Premiere should automatically recognize PAR, for instance importing a 1440×1080 HDV clip into a 1920×1080 or 1280×720 sequence should not require anything on your part.
    In the event that Premiere does NOT properly recognize a clip, right-click the clip in the Bin and choose Modify > Interpret Footage to manually change the PAR.
    Jeff Pulera
    Safe Harbor Computers
  • Zack Yoshyaro
    November 9, 2011 at 12:39 am
    Ah, you are indeed correct! Thanks for the reply!
