Activity › Forums › Apple Final Cut Pro Legacy › Converting for FCP
Converting for FCP
Posted by Preston Orrick on September 17, 2009 at 10:05 pmOkay, so I have a raw clip here, and it’s given me some render trouble in FCP. Below are the settings:
Dimensions: 576×324
Codec: Sorenson Video 3
Aspect Ratio: Custom (16:9)
Pixel Aspect Ratio: SquareThis clip is straight from a Digital Juice DVD. What would be the best setting to convert it to to have it play nice in FCP?
Kai Cheong replied 17 years ago 3 Members · 5 Replies -
John Pale
September 17, 2009 at 10:17 pm[Preston Orrick] “This clip is straight from a Digital Juice DVD. What would be the best setting to convert it to to have it play nice in FCP?
“Generally, you should match it to whatever Easy Setup codec your timeline is. If you need an alpha channel, then you use Animation Codec or ProRes 4444 (FCP 7 only).
Use Compressor to do the conversion.
Preston Orrick
September 17, 2009 at 11:08 pmI’m still lost; even if I do convert it, FCP will still require me to re-render if I move it at all. And, what if I want to convert the odd dimensions into smaller dimensions and not preset dimensions?? I wish FCP was more lax on accepting files. I’m not big on the render every 5 seconds thing.
Preston Orrick
September 17, 2009 at 11:34 pmEven after I convert it to ProRes, it still has these settings:
Frame Size: 576×324
Field Dominance: None
Compressor: Apple ProRes 422 (HQ).. and it’s still being weird about rendering every 5 seconds.
Preston Orrick
September 18, 2009 at 12:05 amMPEG Streamclip has solved my problem. It converted my 576×324 video to 1280×720 (HDTV 720p) without any noticeable issues. And it’s a free program, unbelievable!
Kai Cheong
September 18, 2009 at 3:53 amHi Preston,
If you’re using stuff from Digital Juice, you should be able to tweak the settings in Juicer to best match your sequence. Juicer is their free software available on their website for download.
I use a lot of DJ, too and it definitely saves a lot of time if I render out [from Juicer] a QT file that matches my FCP settings. This is especially so for background plates. Looking at your settings, I guess the issue was the dimensions. Good to hear it’s solved now.
Kai
FCP Editor / Producer with Intuitive Films
https://kai-fcp-editor.blogspot.com
Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
Visit us @ https://www.intuitivefilms.com
MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.2
