Activity Forums Adobe Photoshop Converting Files for video.
  • Converting Files for video.
    Posted by Jon Himes on October 19, 2005 at 8:40 pm
    I know this has probably been covered somewhere else but I can’t find it. I have numerous files that need to be converted to a DV size. I am open the files I want to convert in Photoshop and then open a new file and shrink the one I want to convert and copy and past it into the new file with the DV NTSC 480X720. Is there a batch processing technique because as you can see it takes forever. The Photoshop help is not that helpful in batch processing them.
    Jon
    Richard Harrington replied 20 years, 10 months ago 2 Members · 3 Replies
  • Richard Harrington
    October 19, 2005 at 9:07 pm
    Use the DVD slideshow action in PSCS2…
    Look in actions palette.. laod built-in video actions
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Jon Himes
    October 20, 2005 at 1:45 am
    Thanks for your reply,
    Will this work with the non CS2 version. I have not upgraded from CS.
    Jon
    October 20, 2005 at 12:54 pm
    The actions ship with CS2… they work with earlier CS.. but you’d have to get them somehow
