Activity › Forums › Apple Final Cut Pro Legacy › converting file into qt, to import into fcp
  • converting file into qt, to import into fcp
    Posted by Paul01 on June 4, 2005 at 7:39 pm
    i am having problems converting mpeg2 files into quicktimes, so i can import them into fcp. what settings should i use?
    i sused the 720_low setting, since it is just a temp clip.
    i am converting the file with sorenson squeeze on a pc and then importing he qt into fcp on my mac. but it says it cant read the file. it shows up as a qt file on the desktop. i hope somebody can help.
    Paul01 replied 21 years, 4 months ago 1 Member · 1 Reply
  • Paul01
    June 4, 2005 at 9:18 pm
    i figured it out, bought quicktime pro, export as qt, works perfectly.
