Converting EX-3 footage outside FCP
Howdy from Texas,
I’m running into some problems where the fcp plug-in is not recognizing the EX-3 Files within the BPAV folders. The log and transfer pulls files from before the files in the sequence and after but not these in particular. There is nothing wrong with the file path as I have triple checked every thing. I’ve combined spanned footage into one folder but nothing still. I have done a voodoo dance and chanted to the XDCAM spirits of yesteryear, but nothing….
VLC player has no issue playing these files which means they are not corrupted.
My question is, is there a way outside of Final Cut to convert this footage into the same file that the FCP plug-in does? After doing so I would simply import that footage.
If not, then is there a way to simply convert those .mp4’s into .mov’s? MPEG Streamclip does not recognize the .mp4 footage.
Thanks for the help,
David
