Activity Forums DVD Authoring Converting DVD to youtube format?
  • Converting DVD to youtube format?
    Posted by David Lord on July 17, 2013 at 1:08 am
    Hi everyone, sorry if this isn’t the right forum to post this in. I have some old projects from Adobe premiere on DVD, and I no longer have any of the original project files. I want to know if there’s a way to copy them and change them to a format appropriate to upload to youtube. Thanks in advance!
    Jeff Pulera replied 13 years, 2 months ago 2 Members · 5 Replies
  • Jeff Pulera
    July 17, 2013 at 2:08 pm
    Hi David,
    Copy the .vob files from the DVD to a hard drive on the computer, then Import those files into Premiere and put in a Sequence. Edit if need be, and then Export using an H.264 YouTube preset.
    Jeff Pulera
    Safe Harbor Computers
  • David Lord
    July 17, 2013 at 2:33 pm
    cool thanks! that sounds easier than I expected. but isn’t h.264 a high definition format? these are some old videos I recorded on mini dvr.
  • Jeff Pulera
    July 17, 2013 at 2:53 pm
    H.264 is whatever resolution you need it to be, it not an HD format specifically.
    Jeff Pulera
  • David Lord
    July 17, 2013 at 3:25 pm
    sorry, last question. would there be any benefit to exporting in h.264 over MPEG 4? that’s always what I used to export in.
  • Jeff Pulera
    July 17, 2013 at 3:27 pm
    No, MPEG-4 has very limited options for export. Definitely look under H.264 and there are several YouTube presets when you scroll down, I believe they do have a “YouTube SD” preset, just use that.
    Jeff Pulera
