Activity › Forums › Compression Techniques › converting DVD into editable format
  • converting DVD into editable format
    Posted by Marten on January 7, 2006 at 8:51 pm
    Hi, its Marten from Barcelona, i need to convert a DVD into a format that i can import into Final Cut. This is for a documentary on the early days of surfing in south east asia… Thanks a lot if someone mght be able to help.
    Charles Simonson replied 20 years, 8 months ago 3 Members · 3 Replies
  • Charles Simonson
    January 9, 2006 at 1:16 am
    Try using MPEG StreamClip. Many options and very fast.
  • Mike Cohen
    January 11, 2006 at 11:52 pm
    sub the DVD to DVCAM or whatever tape format you use, then digitize it the usual way.
  • Charles Simonson
    January 12, 2006 at 3:13 am
    The problem with that is that most DVDs are progressive, and most DV cameras are interlaced, so you would introduce a significant loss in quality with that method.
