Activity Forums Apple Final Cut Pro Legacy converting dvcprohd to sd sequence
  • converting dvcprohd to sd sequence
    Posted by Jeff Wilmes on April 13, 2007 at 4:04 am
    I have successfully nested/dropped a dvcprohd sequence, unedited, into a sd sequence letterbox. I am now trying to do it again and it is not working.
    Original timeline settings:
    HD(960×720) (16:9) Frame Size
    HD(960×720) Pixel Aspect Ratio
    Editing timebase: 59.94
    Compressor DVCPRO HD 720p60
    New sequence:
    720×486 CCIR 601
    720×480 CCIR 601
    59.94
    Uncompressed 8-bit.
    I already have successfully done this once. If I try to put the editied sequence into either the old successful sequence, or a new sequence, it is squeezed. If I take the successful, unedited footage, and put it into the new sequence, it works. For some reason the edited footage does not want to conform/nest/convert to letterbox. Any help?
    Jeff Wilmes replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
