Activity Forums Apple Final Cut Pro Legacy Converting DV into SD codec for colour correction, will it help?
  • Converting DV into SD codec for colour correction, will it help?
    Posted by Edward Howard on April 19, 2005 at 11:59 am
    Hi there,
    I’ve been colour correcting in the DV codec for a while and I have found that I getting some unacceptable noise in the mids and blacks. Would converting the media to SD or dropping the the project onto a 8 bit SD timeline help? (I have fast enough stroage to do this).
    Cheers,
    Edd
    Bret Williams replied 21 years, 4 months ago 2 Members · 1 Reply
  • Bret Williams
    April 19, 2005 at 1:12 pm
    As long as you’re going back out to someting better than DV. If you’re just going back to DV at some point, all your hard work will be obliterated, AND you will have run your project through one extra process.
