Activity › Forums › Apple Final Cut Pro Legacy › Converting DV 720×480 to uncompressed for final render
  • Converting DV 720×480 to uncompressed for final render
    Posted by James Honce on September 10, 2007 at 1:47 pm
    All of my projects are shot in DV either 4:3 or 16:9. I have read a lot about the benefit of working uncompressed for the graphics and text.
    If I edit my entire project as standard DV 720 x 480, can I simply change the codec to 10-bit uncompressed for the final render or do I need to change the sequence size to 720 x 486 as well?
    The basic question is can I edit uncompressed on a 720 x 480 timeline or does it have to be 720 x 486.
    Jamie
    Russell Lasson replied 19 years ago 2 Members · 1 Reply
  • Russell Lasson
    September 10, 2007 at 2:42 pm
    I use uncompressed at 720×480 quite often and have never seen any problems with it. I’d say you’re good to go, especially if you’re going out to DVD (720×480).
    -Russ
