Activity › Forums › Canon DSLR Cameras › Converting DSLR 8bits to 10 bits technique for preparing post
  • Converting DSLR 8bits to 10 bits technique for preparing post
    Posted by John Mayer on May 4, 2016 at 1:33 am
    Hi, I am trying to do this technique this guy show on his channel
    https://vimeo.com/19908622
    this look to be a great solution for high profile CC, however I don’t have the tools he got.
    I have Neat Video but only for Premiere, and I don’t have Cineform.
    Is it possible to replicate this kind of technique with other codecs supplied with Premiere? And is there a way to kind of batch process this technique?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    John Mayer replied 10 years, 4 months ago 2 Members · 2 Replies
  • Warren Eig
    May 4, 2016 at 4:15 pm
    Are you on a Mac or PC? If on a Mac, there is a great utility called 5DtoRGB Batch which converts from h.264 to ProRes which is 10 bit. You’re just taking an 8 bit file and putting into a 10 bit container, but the video is still 8bit. Your benefit comes in when you do a lot of post processing. Any banding issues in the 8bit video won’t magically go way once converted to 10bit.
    Warren Eig
    O 310-470-0905
    email: info@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • John Mayer
    May 10, 2016 at 12:02 am
    thanks, however I’m on PC, seems like 5DtoRGB is only for mac.
    Meanwhile I found out that Adobe kinda come with Cineform itself. By using the Gopro Cineform codec Quality 5 is equivalent to Film Scan 2. I put my files in my timeline and with the project manager they will output 10 or 12 bits files.
    The bandings issue won’t likely to be fully resolved, but it could be greatly reduced with filters which is one benefits of this technique by using neat video and noise filters. I already did few tests and I had some convincing results.
    Only I have to do this on every clips because Lumetri filters seems to not like at all 8 bits footage or there will be huge artifacts. I don’t know if there’s a way in Premiere to make a batch with filter applied, that would speed up the process.
